ExtLibA.SockLib.CreatSockHndlFail
Description
Failed to create a socket handle.
Remedy
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Severity
Error
Message Text
Failed to create a handle to a socket. Application socket handle = %p1% Socket type = %p2% Socket family = %p3% Socket protocol = %p4%
Message Parameters
Name Type
p1 uInt32
p2 xInt32
p3 xInt32
p4 xInt32
